I'm working in a vacuum here- not a lot of trucks around here to look at, and I could use some help. Even the junkyards trucks are all striped.
I have a 1970 f250 with a 390, and I'm hoping to see some detailed photos of both the horns and the windshield washer system. My truck came to me without either, and I'm having trouble visualizing the setup. I suspect I'm missing some brackets for the horns and I know I'm missing everything for the windshield washer system.
It's not an emergency, but next time you're snapping images could someone post one (or more??) with those details? I've scanned the gallery, and while these items are included in the picture, I trying to get more details.
Thanks in advance!
fn
Image request, please?
- Fake Name
re: Image request, please?
Here are a few picks off my truck 72 250 The setup is the same. The driver side should be mounted up in the big square hole on the radiator support. Then off the back of the washer fluid can there is a rubber line that goes up to the cowel, there is a fitting that splits the line into two, they go to the jets. Hope that helps. If you need better or more picks just ask.
