howdy
i'm taking some badges off of my truck, i got the custom cab badge off of my truck, and i tried to get the 390 badge off with a butter knife, and screw driver and it didn't work too well. it bent a little so i stopped. my question is: what's the best way to remove my 390 badge and the F O R D on my hood?
BADGES!
- jor
re: BADGES!
The FORD letters come off easily. Here are phots of two different attachments you might see. The blue ones are stock and the red, some replacements I used. In the case of the blue, the letter should pop out with the method you are using (careful prying). With the red, however, you need to unscrew the keeper nut (don't know what you call those things). In the other photo, you'll see a close-up of one of the barrel nuts (another made-up term) on another piece of trim. Good luck!
jor
jor
- mk
re: BADGES!
The 390 emblems should have the same type of barrel clips as the custom cab nameplates. I think they have 3 pins. Use caution
mike
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
~Will Rogers
To remove the F O R D hood letters I use a punch and a hammer and push them out from the inside of the hood. Tap Tap Tap.. couple taps on one side.. then couple taps on the other so they push out evenly.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
