So I'm pulling the box off......
just took a quick look at it and a previous owner has welded a sheet of diamond plate right over the original floor/bolts.......so my question is am I gonna be able to still get at those bolts to get them off from underneath .....and also anybody have a picture of there bed so i can see where they are located
..................................... ___
..................._________|___\____
..;.;;.:;:;.,;.|__(O)____|____/_(O)|
re: So I'm pulling the box off......
If you're planning on keeping the diamond-plate, just remove the nuts from the bottom side and then lift the box straight up. You don't need access to the bolt heads...unless they start spinning when trying to remove the nut.
You won't be able to get an impact on them, unless you use a U-joint connection. However, I'd advise against it. It's very possible for the square shank of the carriage bolt to round out the hole in the box...making removing it next to impossible...and using an impact is more likely to cause that then just a breaker bar and socket. I'd spend some time with a wire brush and some PB Blaster, getting them as clean as you can first, and then try removing them very carefully with the breaker bar and socket first.
I am in the middle of working with my bed also. I'm not sure what you are describing. There are a total of six fasteners holding the bed to the frame on a long bed. There are three through the upper surface of the bed and two at the most aft point that are accessible underneath.
As far as I know you can reach all of the nuts from underneath. The only acceptation is with the installation of a the Saddle Tank option. At that point there is a nutplate and the fastener is installed from the top. All of the other fasteners are stove bolt type design.
Good luck, Ric.
Good luck, Ric.
Ric Tucker
71' F100 Sport Custom
66' F250 Camper Special
- FoMoCo
Sounds like it is rusted badly. If all else, cut the bolts off at the frame with a right angle grinder and grind down what's left till flush with the frame.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- jor
Here's some photos showing the location. A bit hard to see.
jor
jor
- jor
You can still get to this nut but it takes some doing. It's the front left-most bolt. Here's a photo.As far as I know you can reach all of the nuts from underneath. The only acceptation is with the installation of a the Saddle Tank option. At that point there is a nutplate and the fastener is installed from the top. All of the other fasteners are stove bolt type design.
jor
Missing the Picture.
Ric Tucker
- rjewkes
My 72 had two more bolts under the bed just behind the back lip/pan of the bed.
fuelly.com
fuelly.com
I am removing a bed off a 72 pickup trailer to use it as body parts for my truck. I used an impact with a wobbler extension to get to the frame bolts and ended up having one bolt out of the eight spin on me. I had to gring it off.
Andy
1969 F100 300i
3 on the TREE
1969 F100 300i
3 on the TREE
- rjewkes
If thbe bolts mean nothing to you and you can remove the plate then use a die or even angle grinder with cutt off wheel and go slow and steady.
between the frame and nut or even cut the nuts in half verticaly.
fuelly.com
fuelly.com
