massive suspension overhaul
my suspension is shot and i need to get it fully redone practiculay the only thing not shot is my front coil springs i was wondering where i would get all the parts from at a reasonable price i took to some1 in town a month ago and they couldnt find any parts.
- 19674x4
junkyards woud be agood start. whoesalers, and places like the bronco graveyard. should be abe to get you a good dea, also keep an eye out for a donor truck that you could buy to use the suspension off of.
My Photo Album
- FoMoCo
re: massive suspension overhaul
Are you wanting to replace the cast parts or rubber parts, and king pins. If it's that bad be sure to clean and inspect things such as the radias arm and I beam mounts. Ive have to replace several of these on later model trucks.
nick
nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
I got all the front end parts for my 69 F-100 at local parts stores with no problems. Schucks ordered my coil springs, but I had them the next day. They had all the steering linkage in stock. Shocks were no problem. NAPA had the king pins. The only thing I mail ordered were the bushings because I wanted poly instead of rubber. You just need to find a parts store that has someone that knows something.
69 F-100 Ranger 302
Kingpin sets are about $50 and then an additional $50-$75 to have them pressed in for you. Axle pivot bushings, radius arm bushings and rear leaf-spring bushings are very inexpensive at virtually any parts store.
i replaced all 4 shcoks on my 68 for around $80, took 35 minutes (easy). Autozone always has what i need.
