do i need 2 of these
- customcrewcab
just wondering if i need 2 adjusible proportioning with a tandem chamber master cylinder. they only have one inlet and one outlet so i don't see how they can ajust both front and rear line presure. if i get two i just need to put one on the outlets of the the master cylinder going to the front and one on the rear.
http://www.fordification.com/galleries/ ... ?cat=10106
![Image](http://www.fordification.com/images/forum/ty.jpg)
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
- 68F250
re: do i need 2 of these
A proportioning valve is normally installed in the rear fluid line to prevent the rear brakes from locking before the front. There's no reason (and not recommended) to reduce the pressure to the front, at least on the street.
Barry
- customcrewcab
then i can run the front of the master cylinder straight to the front brakes and the rear to the valve and the to the rear brakes? this it what i thought but it didn't understand why the both went to the stock proportioning valve. i guess to have shorter lines so they would be easier to be replace. i am going with integra 6 piston calipers and 13" rotors on a 4 corners so it should stop like a ferrari
thanks
thanks
- 68F250
Yeah but when you say the front of the master cylinder, the larger reservoir closer to the firewall goes to the front brakes and the smaller reservoir on the end goes to the rear brakes.
Barry
- customcrewcab
yea. the one on my 64 falcon are pretty equal. i don't remember which on is bigger on the stock ones. its from a svo mustang. i thinking with going with this wilwood master cylinder.
