hood
edgar
hood
Post by edgar »
i got acouple of dent on my hood and i cant reach then bacause inside the hood are a shield or somethin and i cant reach the dent .what should i do. how can i take it off?
spartman
Post by spartman »
You could try to use dry ice and pop the dent.
yea you get the truck hot like let it set in the sun all day then put dry ice on the dent and it should pop out if its not to badly dented.
edgar
re: hood
Post by edgar »
ok thanks ill try it. the dents are about 2 ,3, inches wide in a circle shape.
rjewkes
Post by rjewkes »
if they are small enough and not very deep, you could do bondo.
fuelly.com
re: hood
As an option, you could always get a hole saw and cut a few access holes in the bracing on the underside of the hood. That would give you a little access to the bottom side of the dent to pop it out. The only time it would be seen would be when the hood's open, and depending on where it's at most people would probably never notice it.
Sharkdance
Post by Sharkdance »
fordman wrote:yea you get the truck hot like let it set in the sun all day then put dry ice on the dent and it should pop out if its not to badly dented.
Will that realy work?
Sharkdance
70 F250 2WD 360/C6
my brother in law told me about it. he used to do body work in his shop. and thats how they fix hail damage too. its all about expansion and contraction of the metal.
rjewkes
Post by rjewkes »
knew a guy who would deflate a basketball or soccer ball asnd footballs. And even kickballs of different sizes and he would put them between the dented pannel and something for support.
Inflate it slowly with a hand pump and viola! No more dent.
fuelly.com
spartman
Post by spartman »
Never thought of that.
Sounds like a test is in order.
qman
Post by qman »
I had a softball sized dent in the hood of my Taurus that was right behind the bracing. It looked like a basketball or something hit it. I coule stick something through a hole in the bracing and push it up but it would come right back down. The metal wasn't creased, just indented. A guy at the paint store told me that sometimes whatever caused the dent will slightly dent the bracing and it's the bracing holding the dent in place. So he told me to whack the bracing with a rubber mallet. The first whack took most of the dent out and after a few smaller well placed ones there is no more dent. A body shop guy told me it was a 4-5 hour job to pull it out. It was more of a 30 second 4-5 whack job.
SmokeyBear
Post by SmokeyBear »
qman wrote:It was more of a 30 second 4-5 whack job.
you killed 4 or 5 people in 30 seconds or you know 4 or 5 people who are crazy for 30 seconds???
:D
70 F-100 XLT
72 F-100 Ranger XLT
fuzzier1
re: hood
Post by fuzzier1 »
Have you seen the adds for Pops-a-Dent (or whatever it is called but I think that is right) on TV, I always thought that it was BS but I had a gas tank on Honda M/C that had a pretty good dent in it and I was going to resale the bike. So I went to Autozone and bought one of those kits for $19.95 and got 99% of the dent out using it. There was one small dent left that was the smaller than a dime compared to 1 1/2x3 inch long dent that I started with. Worked great.
Fuzz
capeclassics
re: hood
Post by capeclassics »
Yep to fuzzy...I've had good luck with the pop-a dent tool.A good $19.95 investment.The local auto parts places also sell a "suction cup" thingamagig for a couple of bucks that works great on bigger dents(say 3 inches+).Happy hunting.
