Resistance when turning right
HOWDY69
Post by HOWDY69 »
I am getting a little resistance at about 1 or 2 o'clock when I turn to the right. It happens at the same spot every time and is gone as soon as I turn past it. I notice it at slow speeds when I slow down to make a tight right turn like pulling into the driveway. I will be inspecting the steering this weekend but I just wondered if this problem rings any bells with you folks.
Manual steering.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
mrsnicks
re: Resistance when turning right
Post by mrsnicks »
Wait until 3 o'clock to turn? :evil: Sorry couldnt resist. Could be something binding up in your steering linkage or steering box? Could be tie rod ends binding up?
Get underneath the truck and start wiggling all the tie rods, the drag links... grease everything up, and your king pins too.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
maybe in the steering box. a rough spot on the gear?
kid
Post by kid »
Most likely a dry spot in the under greased king pin busings.
68F250
Post by 68F250 »
King pins. Try shooting some grease in 'em.
Barry
