How can you tell if you have a posi hogshead after the hogshead/pumpkin has been removed from the rear end? I'm pretty sure I have one.. but I have a couple lying around. How do I tell the posi/limited slip from the open??
Thanks,
Patrick
Posi ID
Posi ID
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- 390Nut
re: Posi ID
Quickest way to tell a posi from a non-posi 9". The ring of bolts on a posi will be countersunk, where as the ones on a non-posi will stick out from the surface.
here's a good page for 9" info, http://www.kevinstang.com/Ninecase.htm
Heres a couple pics, the first being a NON-posi. This is the surface that is to the passenger side when installed, looking from the pinion yoke back it will be on your left.
Paul
`69 F100 390 4spd driver
