do you have any pictures of your original install on the rear end I plan on installing a t bird rear to my 67 and would love to save the 400 they want for the (bolt in) kit
68 F100 SBFS build; CV, T45, DOHC/M122, Cobra IRS
- derbydad276
Re: 68 F100 SBFS build; CV, T45, DOHC
- SATURN5
Re: 68 F100 SBFS build; CV, T45, DOHC, MN12 IRS
Nothing really different other then I boxed in the mounts for a cleaner look.
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
- SATURN5
Figured out the steering on the cheap. 2004-8 F150 steering shaft, which I added 3" too. Modified the original (75) column shaft from 36 spline to the "D" with a notch to match the upper u joint. Cost... $45 shipped.
Bob
- marvin2
Saturn5 that is great info on the steering shaft! Where did you pick one up for $45?!?
- SATURN5
Thanks.
I've got a Mustang buddy who works at a dismantlers in Nebraska...
Bob
- SATURN5
Whittled up a endcap/bearing assembly to replace the worn out factory stuff. Should last forever....
Installed.
Once I repaint the column, I'll keep it in place with 3 buttonhead screws.
Installed.
Bob
- sargentrs
That's some great custom work!
- SATURN5
Cobra manifold fits! Now for the rub... Apparently I bought two left sides... as shown in the auction.. I didn't look that close... Going to contact the seller and see if he's got a right side... Derp.
Clears the steering shaft by about a 1/2".
Bob
- SATURN5
A long cold winter is over. Picked up a fuel tank and got it installed.
Adjustable! Just like factory!
Found this on a Lightning forum. I think I'll copy it from the muffler back. Then adapt from the muffler to the BBK X Mustang pipe. I also bought a 98 Cobra intake. Going to build/mod the engine harness and run a Megasquirt II ecm...
Bob
- sargentrs
Suhweeet!
This is some great stuff!! Giving me some ideas
1968 2wd swb
There's no replacement for displacement!
- Mancar1
Your doing some great fab work.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I was planning on making This myself, but it's obviously a lot easier if I can buy it!
Where did you get the end cap and bearing?
Looking good!
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
Audi S6 4.0 tfsi
Full resto:
- SATURN5
Thanks!
The bearing was a good used one from a tool we serviced at work. I just went thru our pile until I found one with the right ID. The end cap is something I whittled up in my lathe from Delrin. There's an o-ring holding the bearing in place.
Bob
- 48prerunner
Some guy sells something like it on ebay , doesnt look as good as yours . I was just going to put a bearing in there, only wood lathes at work so not turning one there.
