how much better is a disc brake front end?
heep70
re: how much better is a disc brake front end?
Post by heep70 »
Enough bashing. Back to the subject please. Thanks
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
390Nut
Re: re: how much better is a disc brake front end?
Post by 390Nut »
Chaseman wrote:Doesn't the clamping action on the disks provide better stopping power compared to the outward pressure on drums? Also the better airflow over hot stuff to cool down? :2cents:
Technically, yes. Brakes of these types work by transferring kinetic energy from the moving part (drums or rotors) to the non-moving part (shoes or pads). This transfer creates heat in the form of friction. The faster the shoes or pads can absorb and dissipate that heat, the more braking force their is. If the parts can't dissipate the heat fast enough, you get brake fade. The significant difference is the fact that disk brakes use a clamping force from a relatively fixed position rather than outward pressure from a moving position (inducing more flex in the entire system) . The other key factor is that there are TWO surfaces being acted upon, instead of one, and being open to the air they cool much more rapidly, allowing greater energy transfer in a quicker manner.
Hence the reason why disk pads are generally smaller in surface area then drum shoes, and still provide as much if not more energy transfer.
heep70 wrote:Enough bashing. Back to the subject please. Thanks
That's what we're doing, Greg, really! :oops:
Paul
`69 F100 390 4spd driver
heep70
Post by heep70 »
390Nut wrote:
Chaseman wrote:That's what we're doing, Greg, really! :oops:
Kewl :thup:
The discussion is very interesting about the two types of brakes. :thup:
Greg
OldRedFord
Post by OldRedFord »
Im planning to go to disc brakes front and back on my 72 in the future, but for now Ill keep the drums. I dont plan to change till my truck is running fater then 13.5s lol.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
nytreeman
Post by nytreeman »
My power drums on my 1 ton dump work fine stop great but I always have to keep them tight and they do fade on the downhill unless you give them a pump here and there along the way dont want to be riding them hard with 4 or 5 facecord of wood on the back!....but discs aredef easier as far as changing the pads and no adjusting.:thup:
I wouldn't mind the change to discs,except for the fact that mine is a dually so its a little harder to come across the necessary parts :(
~ Don
So much rust ... so little time
my gallery- http://www.fordification.com/galleries/ ... ?cat=10447
AlleyCat
Post by AlleyCat »
nytreeman wrote:My power drums on my 1 ton dump work fine stop great but I always have to keep them tight and they do fade on the downhill unless you give them a pump here and there along the way dont want to be riding them hard with 4 or 5 facecord of wood on the back!....but discs aredef easier as far as changing the pads and no adjusting.:thup:
To do the disc swap on an F250 you remove the drums and backing plates then install the caliper anchors and rotors.Does anyone know if an F350 works out the same way? :hmm:
Clay
390Nut
Post by 390Nut »
Going to have to wait for someone who knows the F350 trucks better for a good answer.
I do know that the F350 has a thicker diameter kingpin than the F250, and the radius arms are heavier (along with different frame mounts and bushings) but I do not know if there were changes between the years.
With that said, `67-`79 F350 all used the same kingpin, so it's possible the same spindles were used that whole time.
Paul
