Brake lights gone
kid
Post by kid »
Straighten out a coat hanger and slide it down. Hook the wires to the end with tape and pull them down. All of my trucks present and past had a wire guide tube inside the column and mine just slid down the tube and were fished out with needle nose. Conduit to us electricians
ICEMAN6166
re: Brake lights gone
Post by ICEMAN6166 »
i used some bailing wire but works the same as a coathanger. its pretty easy.
real fun is pulling several big fat stiff wires thru a long run of conduit and around a few bends.
cjs_72f250
Post by cjs_72f250 »
yes, i've been using a coat hanger wire all morning and it's been a struggle! i'll keep trying. the problem is the new wires bunched together are just too darn thick and won't fit through that narrow space. one issue is the new turn signal switch has an extra wire going to second horn spring/button. that wire is a pretty big gauge as it is much thicker than the other wires.
do you guys recommend tightly taping the entire length of the wires to thread them down or just tape the initial part to the coat hanger?
thanks
'72 F250 Explorer Camper Special
kid
Post by kid »
Baby oil since you aren't an electrician you don't have Elephant snot laying around. Yellow 77 (Elephant snot) makes any wire fit.
Pull them out tight one at a time and then tape the ends together so you don't have loops and waves causing it to bunch up.
theskytoucher
Post by theskytoucher »
kid wrote:(Elephant snot)
AKA honeymoon helper!!!! :eek:
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
kid
Post by kid »
:D :lol:
cjs_72f250
nice tip. i'll try it and see how it works.
(keeping my fingers crossed...)
cjs_72f250
i attached one wire at a time to the coat hanger and pulled each individual wire through. took me about 30 minutes instead of two hours of struggling and sweating getting all the wires in at once! :woohoo:
boy, am I relieved i finally got those wires through. i haven't had a chance to check on all the turn signal indicators (front and rear), but i did notice that the right turn dash indicator is still lighting up when i turn the running lights on. kid, you mentioned that this means power is coming from another line and that there was something with your front right turn bulb. i recently replaced the entire housing and bulb for my front right turn indicator. could there be some issues with the wires connecting there? i won't be able to check again until tomorrow morning probably, but was wondering if that could be it.
i'm hoping to check tonight on the operation of all the turn signals and brake lights and emergency lights.
so my two questions are:
1. is the power to the steady right dash turn signal due to my changing the front turn signal indicator housing and bulb?
2. why does this new turn signal switch come equipped with an extra horn button and wire? is it for a dentside or something? everything else seems to be the same, just an extra horn button/spring.
cjs_72f250
Re: re: Brake lights gone
cjs_72f250 wrote:so my two questions are:
I think I just figured out my first question. I tested the brake lights and turn signals tonight when the sun went down so I could see the lights better. As soon as I put my running lights on, the steady right turn signal in the dash came on. The right front turn signal indicator was out while the left and both rear lights were on. I tapped the front right lens a few times with a bit of force and the light comes on...dash light goes out. There's definitely something going on with the wiring on that housing that I replaced. I'll tinker with it tomorrow probably.
As for the second question, anybody have ideas on that?
is your turn signal housing grounded properly. the turn signal switches are different from i think mid 69 or 70 and up. they were changed because of the plug under the dash on the earlier models had a single plug wear as the later models had two plugs. if it has only one extra wire it wouldn't be a dent side. if it were a dent side it would have two extra wires for the hazard switch in the dent sides column.
kid
Post by kid »
The light bulb will cause that problem of the elements are touching inside. I have one that will do that.
cjs_72f250
ahhhh, finally. all turn signals, brake lights, and instrument panels are back to working normally. the right turn signal housing and bulb were loose and needed to be grounded tighter. thanks to you all for the help. kid, you provided a lot of great help. :thup:
