Started mocking up the spares
Made the rear spare holder bumper deal
Made fuel cell straps, cut heads off of bolts and tacked them to the straps. Tacked tabs to the fuel cell base. Same as before but needed to remake them because they are longer now.
After drilling out the sleeve for the bedside mount and putting taillights/marker lights back in
Also made the rear bedside mounts. Not done yet in this picture but smaller tube slips into larger tube, with a bolt running through them so i can pull the assembly off not just the bedside. or i can unbolt just the bedside if i want. I used the original tailgate mounting holes.
Then i trimmed the bottom/rear of each bedside, I think it made them look much better. Also took an inch off of the whole wheel well opening because that inch was mangled all the way around. Still going to try to get the bedsides more smooth and they need some new paint
Dad went to the junkyard and pulled brake calipers and rotors for the 1" kingpin front steer spindles i got from the swapmeet and put those on so now we have true front steer spindles and brakes hooked up. I'll do the brake lines tomorrow
A few hood pins and the whole body is finally mounted
Set some things back in the interior just for fun... notched the instrument cluster so it can still be used. Original dash is the best!
Need to figure out upper shock mounts for the FOA's again. Speaking of these shocks... I just got them back from FOA. They rebuilt them for me since one of them was having a problem and now they feel great.
Also, dad dropped the stock driveshaft and the HAD driveshaft off at a driveline shop. Getting the final driveshaft back tomorrow. Having it flipped so the slip shaft is at the rear so rocks can't ding it like it normally would.
All time least favorite part of building stuff. Wiring. maybe i can get my dad to do it again. Please? I plan on ditching all original wiring since i only use a couple things from it now.
Now i just WISH that the truck was as ready-to-go as it looks like in the last couple pictures.
Still need everything to do with steering from steering wheel to wheels (except spindles now), tranny coolers/fan mounting, weld everything (everything i have done since tear down is all tack welded), all wiring, hydro bump mounting, limit straps, brake lines, passenger seat mounts, plate some of the 100 speed holes in the cab shut, install carb/wiring on engine, hood pins, complete bolt check, then some much needed urban prerunning!!!
Going to try my best to have it fully driveable by april 16. That gives me two weekends. Might not be enough since it needs all steering but i really want to drive it to the april 16 vorra short course race.
