Horn doesn´t work!
pocoloco63
Re: Horn doesn´t work!
Post by pocoloco63 »
I purchased a horn brush for my 63 Ford F 100 but it is too small for the hole under the horn pad. Is there another piece that goes under the horn brush?
Thank you.
pocoloco63
What is the part that is shown in the attachment that goes under the horn brush? I purchased a horn brush on-line and it will fall to the bottom of the hole in the horn ring if there is not another part below it.
Thanks!
sargentrs
Post by sargentrs »
The horn contact sits in a pocket in the turn signal switch.
91Bear
Post by 91Bear »
Florian wrote: Tue Apr 06, 2010 1:12 pm Hi!
The horn on my 71 F100 does not work. I´ve got no clue when it comes to wiring, so what can I check first?
Thanks!
Did you ever get your horn sorted out?
