Ok... I got the truck back!
Overall, the braking was MUCH improved over the manual brakes. With the manuals I felt I had to put all my weight on them just to stop the truck. With the booster, I pressed the pedal down the first time and almost bit the steering wheel!
That said, I still feel there's a little too much travel in the pedal before my brake lights come on and braking begins. However, my mechanic said that if he turned it one more turn, they started rubbing. I'm not sure where else to adjust it?
As for the brake lights... he said the wires were loose. That's possible. I'll probably pull the connectors to the switch and put some dielectric grease on them. I'm not 100% sure that the switch is mounted right, though. It looks to be at a bit of an angle. I need to look at it more when I have daylight and time.
Also, to follow up on previous discussion... there
IS a small gap now where the old MC formerly came through the firewall. As was indicated by seattle67, the rubber "boot" that comes with the Cardone booster is
NOT long enough to fill that hole. I looked it over, but I also don't see where the rubber cap on the end of my Bendix MC would work... it's specifically designed for the MC. I think I need an "original" boot if I want to fill that hole. Either that, or.... anyone have any ideas?
And finally... I pulled out the old corroded electric/hydrolic brakes. That sure cleaned up the column and gives me a few extra inches of knee room! It also helped that I now have 4 less wires running through the firewall!
