1967 F-100 project
67nukeford
Re: 1967 F-100 project
Post by 67nukeford »
Green sales in Cincinnati hooked me up with the corner parts. Here is the inner support mocked in.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67nukeford
had to do a repair to the support that runs across the back of the box.
Pat 1967 F100 4WD
67nukeford
Everything primered and ready for assemly.
Pat 1967 F100 4WD
67nukeford
Inner support welded in, then the outer corner. Came out really nice. Just have to fab up a piece to cover the side marker light.
Pat 1967 F100 4WD
67nukeford
On to the box sides, starting wit the drivers side. So, I attempted to save the rear half of the drivers side. It was pretty pitted on the back side, and the metal was weak in those areas, so I attempted a series of patches. As you can see, it was just a bit much, so, I rolled the dice, and bought the back half box side from LMC. Haven't had a lot of luck with these guys. This wasn't the greatest either, it was going to take some massaging to make it work.
Pat 1967 F100 4WD
67nukeford
Of course, the stamping was right, so, I had to massage the belt line to fit. This was not fun.
Pat 1967 F100 4WD
67nukeford
Original panel cut in half, and new piece fitted.
Pat 1967 F100 4WD
67nukeford
Wanted to install the fuel door, before I welded the bed sides on. Robbed this from a 79. Made a backing plate for it, and marked the hole in the box side.
Pat 1967 F100 4WD
67nukeford
cut out the hole, and then made a mount for the filler spout. This one is from a Dodge chassis cab truck. Cut out the hole in the box floor to fit the filler mount. And, yes, I made the damn cut too big on the back side, so I'll be welding some of that metal back in.
Pat 1967 F100 4WD
67nukeford
Clamped in the fuel door panel and welded it on. Oh, and fix the too-big hole on the back side!
Pat 1967 F100 4WD
hfdco4
Post by hfdco4 »
Wow really nice work.
Paul
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
67nukeford
After resizing the hole in the box floor/side, I made up a cover for it.
Pat 1967 F100 4WD
67nukeford
prepped, welded, primered
Pat 1967 F100 4WD
67nukeford
also prepped and undercoated the bottom of the cover.
Pat 1967 F100 4WD
67nukeford
finally time to get one of the box sides back on. Undercoated the back sides of the drivers side, and then applied weld through primer.
Pat 1967 F100 4WD
