Not if the leak were at the bottom side and drawing in oil.FORD428CJ wrote:If you had a vac leak....You would be lean and one of the plugs might reflect that!
But with a cast intake and std. Fel-Pro's you should be ok.
![Image](http://i101.photobucket.com/albums/m41/convincor/Fail-Pro%20Printo-Leak/000_1324.jpg)
Thanks!! I was stuck on the buttons on top of the window and not looking!Dragon wrote:It takes to steps after you select the file with the "Choose File" function you click "add file" Then the window switches and you hit "place inline" for every file. It is not the easiest to do because it puts the code where ever it wants.
convincor wrote:Not if the leak were at the bottom side and drawing in oil.FORD428CJ wrote:If you had a vac leak....You would be lean and one of the plugs might reflect that!
Dragon wrote:Those are so rich that the truck is sick.
Carb problem. What model number is your carb? Not CFM the model number is on the air horn.
LMAO! Even though I'm pissed at myself, you folks brought a laugh!DuckRyder wrote:Some 600's are backwards on the idle screws, I agree we need the list number off the air horn.
Bet it gets awesome fuel mileage...
Dragon,Dragon wrote:I just emailed a friend of mine at Holley about the carb since they list almost every carb they ever made on the site but no 81453. They do list a 80453.
Does this look like it.
http://www.holley.com/0-80453.asp
Get this manual from them http://www.holley.com/data/Products/Te ... R9883.pdf
Page 8IDLE MIXTURE NEEDLES:
Idle mixture needles control the air/fuel mixture at idle. These have been preset at the factory and SHOULD NOT need any adjustments. However, if you feel that adjustment is necessary, you can use the following procedure to do so. When tuning the idle mixture, you’re actually tuning for the best manifold vacuum. Idle mixture needles are found on the primary metering blocks. If you change one idle mixture needle, you must change the other idle mixture needle by the same amount. Here are the proper steps for setting the idle mixture needles.
NOTE: This carburetor is equipped with a “reverse” idle system. Screwing the idle adjustment needles IN will richen the mixture. Backing the screws OUT will lean the mixture. There is a sticker around each needle showing the correct direction to turn the screw.
