390 intake swap
- Dragon
Re: 390 intake swap
I just skin the cork gasket to prevent it from absorbing oil through it's life.
We used to do that with a center punch so the manifolds would bite into the gaskets better,
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
- BobbyFord
Re: 390 intake swap
It's hard when you are working at a dealer, trying to get one car done and another one in right away. The Ultra line of Permatex silicones as well as The Right Stuff (from Permatex) require that the parts be assembled right away and not to let skin but they also recommend that the silicone be allowed to cure overnight before returning vehicle to service.
It's nice when you are working on your own stuff at home and have the opportunity to let the sealants sit overnight. I think the engine remains leak-free for a longer period of time when allowed to sit as opposed to returning to service immediately after assembly.
- Dragon
Re: 390 intake swap
Very true that is where 3M Weatherstrip adhesive came in handy immediate return to service. One thing though it matters not what you use but how clean it is when you seal it up.
I keep cans of carb cleaner as my degreaser at home for sealing things.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
Re: 390 intake swap
Well it's alive! I just have to fine tune things and I need to get off my butt and replace the radiator. I will post pics later when I get back from getting food!
Re: 390 intake swap
Ok, here we go! It was nice and dry when I started and now there is about 4 inches of snow on everything
Since I didn't even think about it I set the intake without putting the 4 middle bolts in first
so I raided my bolt bin and found some 3/8 studs that were about 2 3/4" long and 3/8-16 on one end and 3/8-20 on the other. I got them in finger tight then used a pair of needle nose visegrips and set them in place with some antiseaze. All intake bolts are at 18ft lbs.
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3387.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3388.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3389.jpg)
There was no way in hell that I was going to put that P.O.S. throttle linkage rat nest back on the truck so I went to the pile and made a adjustable rod set up.
I took a strait piece of round stock, put a bend in it and threaded one end then used a piece of Lokar throttle kit that I had left over from an old toy on the threaded end.
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3396.jpg)
For the pedal end I had some old linkage from a T-ram set up, ran 2 nuts about an inch apart then welded them to the other end of the round stock. My welds aren't that pretty (It's embarrassing because I'm better than that and I will beat myself up every time I look at it), I was in a hurry and just wanted the thing back together before it started snowing.
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3394.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3392.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3390.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3391.jpg)
The pedal end just goes through the top hole and has about 2-3 inches of adjustment, the carb end has only about 1/4 inch adjustment but I checked the full travel of the carb and pedal and nailed it the first time so there is WOT with the pedal to the floor and.
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3401.jpg)
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3397.jpg)
So it starts and runs I just have to dial everything in. The 500cfm Eddy works just fine so the it will stay where it is, Im not going to bother putting on a 600 or 650 there is no point. This is a daily driver for my wife until her 48 is done.
This is the new/old problem that I'm dealing with, I did a ghetto J.B. Weld fix on the exhaust leak that held for about 3-4 weeks before it cracked out. I don't want to pull the motor or heads just to drill and tap the holes when all the bolts bust off in the heads.
Anyone know of a good epoxy or some sort of goop that will withstand the heat and still be rock hard so I can just smear it on and seal it up?
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3400.jpg)
![Mad :x](./images/smilies/icon_mad.gif)
- Dragon
Re: 390 intake swap
Looks Great ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- SteveC
Re: 390 intake swap
looks good... i did something simular to my 67's i tried using the factory trapezze set up and foudn that it wouldnt work for the 600cfm holly so i put something like that on mine with a few return springs and it works great
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Dragon
Re: 390 intake swap
First thing I do is throw that trapeze away and just use a long rod with ball ends on it.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- dablack00
Re: 390 intake swap
I found that the trapeze works great for the stock intake and carb, but once you go aftermarket don't try and rig it up. Just got with ball ends on a threaded rod. I picked up my parts form summit and mcmastercarr. I have tons of adjustment and no slop.
Now, will someone please send this guy an extra PS pump dip stick? Come one. I know you guys have two or three of them somewhere.
Re: 390 intake swap
LOL, yeah I need a new dipstick pretty bad but I need a radiator even more.
Re: 390 intake swap
that rod looks like the one i have here that someone made. they welded it just like you did yours. what is wrong with your dipstick. other than its blue and the engine is red.
Re: 390 intake swap
He was talking about my power steering dipstick, the handle is busted off. I may just weld a new handle on it or make a whole new one out of an old chevy dipstick.
- dablack00
Re: 390 intake swap
NOOOOOOOO!!!!!!!!!!!!! That cheby dipstick won't work right so close to the distributor. They aren't used to that!Frankenstein wrote:I may just weld a new handle on it or make a whole new one out of an old chevy dipstick.
Re: 390 intake swap
oh ok i finally see it now. dialup takes some time to get all the pics in one thread at one time.
Re: 390 intake swap
WOW, talk about lost power!!! I got it all dialed in pretty good along with getting the exhaust leak patched up with some 2000* Putty from Granger http://www.grainger.com/Grainger/items/2TKR6 (thanks Dragon)
I still have to rejet the carb because I had it set for a slant six and I may or may not fab up a kickdown rod that will work with the Eddy carb, it is my wifes daily driver and she only goes on the freeway for 2 miles so I don't think that she needs the passing gear. I was going to get the Accell points eliminator kit at the local parts store but the closed it down because of the 3 feet of water that was flowing through it the other day.
The only thing that isn't working is the temp gauge. I was in 3 cars before the truck so I think that it finally kicked the bucket.
![Image](http://i88.photobucket.com/albums/k199/360scamp/72%20ford%20truck/100_3442.jpg)
Thanks for all your help guys!!!!![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
