Putting a power booster on manual drum brakes
67F10YR
Re: Putting a power booster on manual drum brakes
Post by 67F10YR »
I didn't use any bushings going through the bracket because I don't remember any coming out of the '72 bracket. And there shouldn't be any movement of the bolt anyway, right? All movement will be the sleeve turning around on the bolt, and the sleeve has the plastic bushings that came out of it. They still looked ok to me so I put them back in. I just couldn't see butchering up the dash to make the wider neck of the '72 bracket fit. Do you see any problems with what I'm doing?
it might be ok as long as you dont have a clutch pedal to create stress on the bracket from constant use.
67F10YR
Post by 67F10YR »
It's an automatic, so no clutch.
speed bump
Post by speed bump »
FORDification wrote:
67F10YR wrote:What exactly is different about the '67 booster from other years? I pulled a booster from a '69 at a Pic 'N Pull but haven't tried installing it yet. Am I wasting my time?
Yes, you're wasting your time...unless you go back to the Pic 'N Pull and also grab the brake pedal mounting bracket that matches that booster.
Read this:
Comparing Clutch/Brake Pedals and Brackets
A photo tutorial about 'what fits what' in regards to brake pedals and pedal pivot brackets
(Read #5 at the bottom of the page.)
I installed a brake booster and MC out of a 79 F-250 into my 71 F-250 just fine. Pedal and everything else worked just fine.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
91Bear
Post by 91Bear »
seattle67 wrote: I should point out that mine is a 67, and 67's are unique in some ways. For a 67 you will need a booster made for 67 only. I bought mine here.
http://www.partsamerica.com/ProductDeta ... 50&PTSet=A
This site is no longer in service.
parts america was changed to advancedauto.com
they wanted to get away from the western auto names completely.
onetuford
Post by onetuford »
So I've got a master from a 79 and all the disc stuff to go with it. There is a booster on Ebay, and the seller assures me that because there is an adjustable rod coming out of the booster into the cab this unit will work on a 1967...Is this true?
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
