390 PCV problems (*PICS*)
- ToughOldFord
Re: 390 PCV problems (*PICS*)
I don't think Blue used conduit, obviously conduit would leak at all of the seams. Looks to me like he used flex gas lines, like for gas clothes driers would use which would work fine.
- 70_F100
That''s a good possibility. If that's the case, it'll be there when we're all long gone!!
It just looked like some of the flex conduit I've used over the years.
That's not an oil leak
That's SWEAT from all that HORSEPOWER!! ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
![No No :nono:](./images/smilies/icon_nono.gif)
Re: re: 390 PCV problems (*PICS*)
DuckRyder wrote:It is widely believed that when you put a high volume oil pump in an FE that you should restrict the oil feeds in the heads to the rockers.
The drain holes look huge but the head bolts run through them as well and there is actually a pretty small passageway there.
With stock rocker assemblies, a 80-90 Holley jet in the oil feed under the rocker stand is about as small as you want to go.
If you are pooling oil in the heads than that might be your fix.
If the heads are holding a lot of oil, it will make it easier for the valve to suck up the oil.
Sounds like you have at least partially fixed it though.
What method to use for restricting some of the oil flow to the heads/rockers?
I think I might have some pooling especially at the rear.
put the valve covers on oppistie sides. so the pcv will be in frotn on the drivers side. the high part of the engine.
- ForingaMex
blue68
I haven't seen anybody mention this but I'm just wondering wehter you wher using oil resistant hose for that or is it just ordinary hose? You have to use oir risistant hose for that. One more thing, on the "fixed" pictures it looks like your not even runing a PCV valve. Is that some sort of plastic coupler? Just my
Jake
Jake
- DuckRyder
Remove the rocker assemblies. Place a 90 holley jet in the oil feed on each head. It is the passage that is next the the bolt hole in the head where the reduced shank bolt is.replace rocker assemblies.faxon7 wrote:DuckRyder wrote:It is widely believed that when you put a high volume oil pump in an FE that you should restrict the oil feeds in the heads to the rockers.
