Changing bolt pattern
what happened to your 78 f 150 rotors and hubs? they should be the same 5.5
doc
Post by doc »
I have the 5x5.5....I want/need 5x5 pattern....
Thanks!
tybob81
re: Changing bolt pattern
Post by tybob81 »
if you did the 72 galaxie swap 5x4.5 would a 2000 and up or so explorer 8.8 w/ rear disc work? the spring perches would have to be moved but they are real close to the same overall lenght.
tybob81
Post by tybob81 »
If you just wanted 5x4.5 with the galaxie front swap what about the factory drum galaxie rear end? I think they had 9'' rears, could you just swap axles and drums into the f100 factory rear to make it work? or are they a different spline count axle shaft? :hmm: :hmm:
