will it run at 0?DuckRyder wrote:Yes 0 is TDC...
Firing off a new motor is always stressful...
302 with 351 firing order???? why?
Re: 302 with 351 firing order???? why?
- DuckRyder
Yes
Next question,
The transmission is newly rebuilt and I put 4 quarts of trans fluid in. Once I fire the engine up for the first time, do I also add the rest of the tranny fluid during the break in?
- DuckRyder
Did you prefill the converter?
yes its wet.DuckRyder wrote:Did you prefill the converter?
is there any way to prime with fuel? don't want to crank to long before firing?
took about 4 5second intervals before firing.
had to shut it down after 3 minutes. headers started melting wire loom.
- DuckRyder
I wouldn’t think 4 5 second intervals is a problem, fix the loom and go again...
Looking for a bolt on exhaust system. I have shorty headers. Anything out there worth it? I already have mufflers
- sargentrs
Lot of options at Summit Racing.
https://www.summitracing.com/search/dep ... cluded/yes
thanks everyone
Something weird here on the timing
I installed a newer timing cover on my new build. I also installed a newer style timing pointer from the newer 302 engines. with that i used a new timing tape on the new balancer. I found TDC and place the new timing tape exactly where the pointer is. So i created a new TDC because of the new timing cover. Well the weird part is when I checked the timing for the first time it was set exactly at 10 BTDC. I was sure it was set at TDC.
what did i do wrong ?
another weird thing is that as the truck ran it started to smooth out. is that normal?
ok, I did my 25 minute break in. Drained oil and replaced with conventional oil. When do i switch to full synthetic ?
- DuckRyder
Thats bound to spark a healthy debate...
Depending on ring material I’d give it at least a 1000 miles... Probably more...
Need advice.
So the truck starts and idles great. When i put in under load it struggles to run. Seems likes its flooding. at idle when i rev the engine it misses and falls.
where to start?
where to start?
- DuckRyder
What makes you say it’s flooding?
Is the spark strong and have you set the total timing.
refresh out memory on the induction?
Duck,DuckRyder wrote:What makes you say it’s flooding?
just a guess on flooding.
I don't know if the spark is strong.
New Holley carb
Here is the idle clip
https://www.youtube.com/watch?v=pStvtCQsFpg
Here is the reving clip then dropped in gear.
https://www.youtube.com/watch?v=gneex239lzQ
