Forest Service Truck Coyote Swap
Re: Forest Service Truck Coyote Swap
Mounted F150 gas pedal, lokar shifter and ops checked volvo electric power steering. Local shop fabricated new drive shaft.
- Fordkid68
great idea on making the tank removable! should work awesomely!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
Passenger inner fender to firewall mount repair. I had to repair inner hood mount also.
Same thing for the drivers side. Bent up some metal and installed.
- Fordkid68
Lookin good!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Fuel tank installed with stainless steels straps. Parking brake cables hooked up and adjusted. I used two left hand 98 explorer cables which worked good no modifications needed. Now fuel lines, brake lines and I need to buy master cylinder/booster.
- Fordkid68
Wow you are getting so close to driving it!! looks awesome!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Cut hole in bed and made gas door. Went to junkyard and got a 90's F150 door. Put bed back on for clearance check and to make sure I cut hole in right spot. The door is centered in the bed, but tank filler offset a bit. The hinge needs a little bit of work- rust of course! Then I think I will bolt it in so can be replaced and also a bit more adjustable than welding.
- hfdco4
So, any updates? Or are you too busy driving it!
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
1970 F250 4x4
- Fordkid68
How are you?
Any updates?
Any updates?
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
