thanks Ranch, the problem is the steel rod in the center.Ranchero50 wrote:No, you use a razor blade and cut off the excess. Seat both pieces fully using screwdriver handle and cut them off @ 1/16" above flush (long). Then you rotate them in the groove, I think you want 1/4" sticking out on one side and 1/4" sticking in on the other so the break in the seal doesn't line up with the block to cap separation line. Should be a ton of stuff on Google describing it better.
302 with 351 firing order???? why?
Re: 302 with 351 firing order???? why?
Summit is sending a new seal. Felpro said the one I have is incorrect
anyone know where to purchase new head bolts that are NOT ARP? I cant find the stock bolts
- DuckRyder
Nice!
- Ranchero50
Rear sump oil pan? 4x4?
Also note by the amount of corrosion on the head gasket surface that I bet this engine was in a saltwater boat.
rear sump, but not a 4x4Ranchero50 wrote:Rear sump oil pan? 4x4?
- DuckRyder
Was it already in the truck like that? Maybe small blocks are different but an FE won’t go in a 2wd truck with a rear sump pan...BayStYAt wrote:rear sump, but not a 4x4Ranchero50 wrote:Rear sump oil pan? 4x4?
yes sir. it was in the truckDuckRyder wrote:Was it already in the truck like that? Maybe small blocks are different but an FE won’t go in a 2wd truck with a rear sump pan...BayStYAt wrote:rear sump, but not a 4x4Ranchero50 wrote:Rear sump oil pan? 4x4?
- DuckRyder
Good deal, keep us posted on how it is going,
We love to hear about new engines in trucks! Even better with pictures![Very Happy :D](./images/smilies/icon_biggrin.gif)
heads on
Testfit headers but header is touching the block
Also waiting for new timing cover to come in.
![Image](https://i.ibb.co/82TdQd0/IMG-2051.jpg)
2014 subaru crosstrek 0 60
![Image](https://i.ibb.co/NYkNtb4/IMG-2052.jpg)
![Image](https://i.ibb.co/9WMF5T1/IMG-2053.jpg)
- Ranchero50
That's because the 5.0 engines don't have the boss for the clutch pivot point.
I would not run those headers. They are pretty much stock garbage parts and don't flow very well. You should be able to find a pair of used 1 5/8" BBK's for little to nothing. Then just grind the ball flange a little for clearance.
Ranch,Ranchero50 wrote:That's because the 5.0 engines don't have the boss for the clutch pivot point.
Thanks buddy. I am not looking for more HP. I got these for a cheap price. I am finishing them with POR15 Header paint. I wanted to get rid of the rusty manifolds.
Valve Adjustment?
I read you just run the nut down until tight? Is there a torque setting?
Is there no lash adjustment?
Thanks everyone
Thanks everyone
- Ranchero50
If the studs have positive stop shoulders then yes, lock them down. If the rocker fulcrum will slide down over the shoulder then you need to adjust the lash.
I don't like the rotate the pushrod method because I've seen the lifter plunger lower while doing it. I shake the pushrod axially while tightening the nut. Once the pushrod doesn't move axially (inline with the shaft) then add 1/2-3/4 turn of preload on the lifter plunger.
