MLJJONES67 PROJECT CUMMINS put away for winter
- averagef250
The springs are the same. 6" lowboy springs ARE 4" highboy springs. If a spring shop says different don't buy from them, they're retarded.
Mike, I just pulled over 21,000 pounds of scrap steel down the highway at 70 MPH today with the bone stock 4BT in my 71. Before you go dumping loads of money on upgrade parts just get the thing together and drive it. It takes 30 minutes in the truck to upgrade turbine housings.
- averagef250
The 78-79 lowboy trucks sit 2" lower than the earlier highboy trucks to start with, the springs are reverse arch like chevy and dodge. Yes, 6" springs give 6" of lift over lowboy springs. They only give 4" on a highboy. They are the same springs and give the exact same acutal lift to both trucks. It's just relative to where the truck sat with stock springs that's all.
Cool I really only wanted a 4" lift on the highboy anyways so that will work out just right. I plan on running 35's. Not sure what rear gears yet. I need to find where the sweet spot is for the 6bt and 65 to 75 mph down the freeway.
Thanks for all your help.
I am still a long ways off to finish. I still have a lot of high dollar items to buy. Hopefully next year at this time it will be on the road!!
- averagef250
- averagef250
- averagef250
What's a 3g alternator? There are several different ways to mount a Ford alternator to a cummins. The easiest is to just use the dodge brackets. With a sawzall and some filing the ford alt fits the same as the dodge one, just swap on the dodge pulley.
re: mljjones67 PROJECT CUMMINS UPDATE
Here is the 3g and the Dodge alt for comparison and the mount on the engine.
- averagef250
What do you Think of these motor mounts?? I would like to use the original engine stands but this might work also.
http://www.4btswaps.com/forum/attachmen ... 1215432443
http://www.4btswaps.com/forum/attachmen ... 1215432057
