72 F100 project, longbed to short conv, CV swap, 20s
Joshpow
Re: 72 F100 project, longbed to short conv, CV swap, 20s
Post by Joshpow »
you want to come clean rustbuckets tank up like that? looking good. glad youre making progress. nice truck.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
BlueBlood
Post by BlueBlood »
Are you using your stock brake pedal proportioning/metering valve with the hydroboost unit? I wanted to do this same swap but had to settle for an 02 CV front clip because none of the junkyards around my city had any newer CVs. It's alot more work but I can't complain (too much) because I feel I scored with the price for the components I bought. Front clip: disc to disc, diff: disc to disc including watts link and the booster/MC.
Joshpow
Post by Joshpow »
You will need a disc brake proportioning valve. Cant answer any other questions but that one I know.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
BlueBlood
Post by BlueBlood »
Ok thx.
JG F100
Post by JG F100 »
BlueBlood wrote:Are you using your stock brake pedal proportioning/metering valve with the hydroboost unit? I wanted to do this same swap but had to settle for an 02 CV front clip because none of the junkyards around my city had any newer CVs. It's alot more work but I can't complain (too much) because I feel I scored with the price for the components I bought. Front clip: disc to disc, diff: disc to disc including watts link and the booster/MC.
I'm using the stock front and rear drum proportioning valve, seems to work pretty well with the 4 wheel disc.
72 F100 - SWB conversion w/05 crown vic IFS, 8.8 rear w/disc, 20s, 360FE w/overdrive
Project Page: http://www.fordification.com/forum/view ... 22&t=37897
Fo-Mo-Co
Post by Fo-Mo-Co »
Why don't you come rekey my locks for me. I would love to have one key for everything.
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
BlueBlood
Post by BlueBlood »
Really??? I was about to throw mine away. Do you think I can use my stock brake pedal with the booster/MC out of that CV?
JG F100
Post by JG F100 »
BlueBlood wrote:Really??? I was about to throw mine away. Do you think I can use my stock brake pedal with the booster/MC out of that CV?
Not sure, I used a hydroboost setup. Even then I had to shorten the pedal rod. The brake pedal is stock.
BlueBlood
Post by BlueBlood »
Ok thx. I'll try it out. I think I'm going to have do some work to the rod also. I'll post what I find when I get to that step. Thx again.
JG F100
Post by JG F100 »
I've been scouring craigslist for a bench seat lately to replace the dilapidated mess of a seat I currently have. Found this one at the junkyard, first one I've seen that wasnt ripped and it matches. All for $30.
Before
After
JG F100
Post by JG F100 »
Its been incredibly hot this year and didnt do much on the truck. Couple of weeks ago I had some time and began peeling some of the bed paint off, then one thing led to another and before I knew it I was striping it down to bare metal. original color was yellow, then red and then rattle can black. I used a couple of 3m strip disc on the grinder
At this point I wanted to do the right thing and throw some epoxy primer on it but the bed seam needs a lot of work. Some areas need more than just seam sealer, thinking of welding it up. Saw someone stick a metal rod in there and weld it in, may do that. In the meantime I sprayed some 97 cent flat black on it.
Unfortunately now I had way too many colors on the truck and liked the flat black on the bed, dents and all. Went back to home depot and bought some more 97 cent cans, little bit of sand paper and over the next few days started spraying. I didnt strip any of the other panels but just gave it a quick scuff/sand job.
So certainly not the first and probably not the last, another rattle-can flat black truck! tiger stripes and all...
Looks good from a few feet a way but it really needs some body work, I've got some other pics showing areas that need work. I'll post those a little later today.
jp2005
Post by jp2005 »
Bet you feel good! nice very work once again
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
marvin2
Post by marvin2 »
I'm definitely liking the single color look...
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
F100builder
Post by F100builder »
Nothing wrong with rattle can black and tiger stripes!!! :D This is my new favorite shot of my truck at a recent show. I put a fresh coat of Krylon satin black on it just a few days before the show (mine needs some body work as well). It too was about five different colors before it was black.
I want to do this to mine soooo bad right now but I've GOT to focus on my '56 first!!! Keep up the fantastic work man! Looking great! :thup:
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
JG F100
Post by JG F100 »
F100Builder, your truck looks really good, I actually like Krylon the best out of all the rattle can brands out there. here are the "needs work" areas...
This door needs to be reskined or replaced
Big rusty gap on top of the cab, not sure if seam sealer will be good enough, I'd hate to weld this one up too
small rust holes
I'd like to find a better hood
