Welding trim Holes?
flyboy2610
Re: re: Welding trim Holes?
Post by flyboy2610 »
FORDification wrote:One trick I've heard about quite a bit when filling small trim holes is to insert a large nail in the hole from the back side and grabbing it with a pair of ViceGrips, and then welding around the nail. The head of the nail lessens the chance of burning through, and then all you have to do is grind it down smooth. :D
That's a cool idea.
I'm gonna have to remember that one! :thup:
FormerMarine1981
Post by FormerMarine1981 »
crazy larry wrote:keep in mind, anything that can hold moisture on the backside of the panel, will cause rust.
I plan on removing the trim on my truck and was thinking about using the nail trick but this made me think twice. Wouldn't welding the nail seal off openings for rust or is their still a chance of a small gap?
CA180
Post by CA180 »
I used the nail trick the other day when i was welding the drip rail holes up on my c10... Kinda proved disasterous at first. I was blowing bigger holes into the sheet metal. I final got the swing of it, sorta... One hole got so big i had to find a 3/8's bolt to pull through. I think my problem is that my welder has two settings, high and low. But in the end it worked out ok. I still had some small gaps (like 1/32 size), but i will need to go back over them with filler any way. One thing i learned though (and i'm no pro) dont go back and weld after you cut the nail off. I guess if you have the right equipment its not that big of a deal...
Just my .02
MAK
Post by MAK »
That's the same thing I was thinking, especially since the panel is curved in that area and the nail head can't sit flat against the metal. I'm a beginner/horrible welder but I didn't have any trouble filling holes with my mig after I practiced for a half hour on some scrap and got the settings right.
XLT
Post by XLT »
What about duct tape on the backside and stuff and smooth hole with JB Weld? Let dry. Light sand.
XLTrucks from my town
crash_552
Post by crash_552 »
You could try Lab Metal. It's liquid metal that turns kinda pastey when it hits the air. Used that to fill some holes on the chopper gas tank. The only thing is the metal you apply it to has to be no less than 70 degrees, but it works great. You can get it at Fastenal.
Good judgment comes from experience... and a lot of that comes from bad judgment
http://www.fordification.com/galleries/ ... ?album=731
wt4speed#2
Post by wt4speed#2 »
Hey Keith isn't that the rig we looked at when you were in Texas at Chris's? that is a cool set up
http://www.cut-like-plasma.com/index.htm
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
Yes it is...those are pretty damned cool. We watched the demo guy weld an aluminum can together, he made it look almost effortless. I did some research on them later on, and the general impression I got from discussions on other forums was that they were very nice but had a steep learning curve.
However, if I had the $$$ I'd buy one in a heartbeat.
68F250
Post by 68F250 »
Do it the old-fashioned way, lead daddy-o.
http://www.carcraft.com/howto/3065/
Barry
