more rear end questions
re: more rear end questions
thanks for the good info Kaylee. Now it's time to open up that rear end and see what I've got.
There's a couple Traction-Loc pumpkins up on E-bay right now. Here's the seller's auction page: http://motors.search.ebay.com/_W0QQsassZ460racer
If you go the third member EBAY route. Make sure you get the right spline. Your choices on a 9" are going to be 31 spline or 28 spline. Yours is probally 28 unless someone has changed it. Easy to check. Just pull one of the axles and count the splines on the end of it. A clutch pack is about 70 dollars.
You can tell what ratio you have by counting the teeth on the ring and pinion gear. Then divide the number of teeth on the ring by the number on the pinion gear.
Kaylle Jonas
67 F100 SWB 429 C6
66 F100 SWB 390 Car 4spd Toploader 3.5 Traction Loc
65 F250 LWB 352 Granny 4spd
Monroe NC
67 F100 SWB 429 C6
Monroe NC
Thanks guys for all the help
