Dont forget about the turbo-encabulator!
http://www.youtube.com/watch?v=2fjcJp_Nwvk
Blinker fluid.
- 1972hiboy
Re: Blinker fluid.
Rich
Dont eat yellow snow.....
- KnockKnock
Re: Blinker fluid.
Make sure you don't have directional lug nuts though, if you put them on the wrong side your rear wheels produce excessive spin (seems to be a common problem on these trucks - you guys should look into this).chad67 wrote:Rotating your lug nuts will help alot, too.
As to the OP's question - I used to use multi-grade synthetic blend, but since you're supposed to change it out every 250 miles, I decided to just go with the same stuff that the Navy PMI recommends for slicking their skates.
A GM-convert that doesn't believe in bail-outs.
Re: Blinker fluid.
can someone please tell me where to buy the left hand threaded lightbulb grease? normal right hand thread grease causes the bulb to blow!
Re: Blinker fluid.
72 f100 lwb 302 3speed
78 f100 swb 351m auto edelbrock 600cfm Carb (electric choke) & intake
- jimmy828
