Not sure if I want to invest another $90 just to ensure better adhesion over a few bare metal spots. You said yu used the 2K urethane prime on ALL bare metal and didn't have a problem? I think I'll just follow your lead. My paint job was pushed up up by request from the wife so I won't be waiting until 2014 - no sealersargentrs wrote:They do reference feathering in around bare metal places but if you're apprehensive switch to the http://www.summitracing.com/parts/sum-up230 which is recommended for bare metal or finished/semi finished surfaces. If you're going to be a while between primer and top coat you should seal it with something like a clear coat or some other type of sealer. Primer is very porous and it will start rusting back through pretty quickly. I had no issues with what I've done. Took it down to bare metal, sanded with 100 grit, sprayed a coat of the 2K urethane primer, sanded with 150 grit, sprayed another coat, sanded with 250 grit, sprayed the Eastwood high build primer, sanded with 400 grit and then sprayed 2 coats of the Southern Polyurethane 2K white epoxy sealer. The finish is smooth and rock hard. I went up and sat with the guys at Southern Polyurethanes for an hour. I'll be using their coating for my final color so I wanted their recommendation. I let them know that I was going to primer and seal and it would be close to a year before I'd be top coating color. They recommended that white sealer. That was 6-8 months ago and still shows no sign of bleed through rust. Hopefully I'll be spraying color next month. I also trust BobbyFord's recommendations.I just met with those other guys first.
Thanks again, sorry I have so many questions.
