'69 F250's rock!
I have a '69 F250Camper Special myself! If you don't have disc brakes, I would suggest you seriously consider swapping over to them. It's really not very hard to do.
Welcome to the boards!
New to Fords with a '69 F250!
- flyboy2610
Re: New to Fords with a '69 F250!
- robbkramer
Not a bad idea . . . what's the rough cost and are the parts easily available? I noticed a set of instructions on how to do it somewhere on this site . . . Since I"m going to have it on stands for the next two weeks I might as well make an improvement!
- flyboy2610
Probably the hardest part to obtain will be the caliper mounting brackets and dust shields, 2K004 and 2B301 in this picture. The rest is available from a parts house.
I just did this last fall:
http://www.fordification.com/forum/view ... =5&t=61368
Robroy also did a great write up when he did his:
http://www.fordification.com/forum/view ... 22&t=38822
While you have it up on stands, you might want to look at the king pins, and check the I-beam and radius arm bushings. Get it all out of the way at once. I have to have the king pins done next spring.
- robbkramer
At some point I'm going to ask you for a parts list and where you bought everything. For now, I'm going to rebuild the drum brakes and get the truck roadworthy. When I have my shop back (ok, garage cleared out) I can tackle the conversion. I haven't worked on drum brakes for oh . . . . 20 years? I can't even remember what I had with drum brakes on it other than my old 52 Chevy!
Sent the carb our for a rebuild, have a new carpet kit, headliner, LOTS of brake parts . . . will be a fun weekend!
flyboy2610 wrote:Probably the hardest part to obtain will be the caliper mounting brackets and dust shields, 2K004 and 2B301 in this picture. The rest is available from a parts house.
