Brake rebuild
flyboy2610
re: Brake rebuild
Post by flyboy2610 »
You're welcome. :)
Heavenlyfire
Post by Heavenlyfire »
well she is up and running, ( and stopping ). Thanks for the help guys.
baddraw
Post by baddraw »
one little update most brake fluid will draw moisture in with one exception Dot 6 which is silicone based fluid and will not draw moisture in and also has a much higher boiling point.
Heavenlyfire
re: Brake rebuild
Thank you, I did not know that. Here in Arizona, the boiling point can be an issue.
shrektruck
Post by shrektruck »
If you have a digital camera or a polaroid take a pic of the springs and cables before you take it apart. Pay very close attention to the auto adjuster-if you put it in backwards it doesn't. (auto adjust)
Matt
