For the moment, ignore the way the brake pedal feels. It will never feel right while air is in the lines.Madsen1970F100 wrote:OK, I checked a few things and I diconnected brake lines at the distribution block and it does "spit" brake fluid to that point when you pump the pedal. However it does not fire a steady stream, as I would expect. I am wondering if the fittings I got (one came with MC) are somehow the wrong ones. Or maybe this is a sign I am not getting the full stroke distance I need?
When you depress brake pedal, it feels a little firmish (not like when you have brakes or anything, but firmish and steady going down to the floor, then towards the bottom it sort of gives way and drops last little bit to the floor, like its moved passed a certain point and no longer has any resistance? Does this give a clue of anything??
Mostly I just focused on other things today. (see my posts on project updates)
Could not allow myself to be caught up and frustrated all over again. It is a holy day of football after all. Figure I'll take a fresh look at it next weekend.
Maybe these fittings need to have a flared end rather than flat???
Did the fittings come with the master? Are they the adapters that are only needed on certain vehicles?
I've been wondering about how it is that you bleed the wheel cylinders. Typically, it is a two person job. With the all the fittings tight and all the bleeders tight, press the pedal down, then open one bleeder. Close the bleeder and release the pedal. Repeat until the fluid is clean and free of air bubbles. Then do the next wheel.
If you don't close the valve, air will get sucked back up into the lines.
There is a thing called "Speed Bleeders". I've never used them, but they are designed to allow a single person to bleed brakes.
