I fliped the hanger
sport71
Re: I fliped the hanger
Post by sport71 »
belair53 wrote:I'm in the process of flipping my front hangers also. I started out just going to change my center support for the drive shaft and the next thing I know I was cutting the heads off the factory rivets. I'm having a hard time drilling out the center of the rivets but I'm getting there. Wish I had taking pics before I started. Going to post pics when I'm finish.
:thup:
Those who do not learn the lessons of history, are doomed to repeat it.
You're trying to DRILL them out?! :eek: I'll bet that IS giving you fits! Heck, just grind the heads off the rivets and then use a BFH and large punch to drive the rest out.
knocking them out is the perfered way to do it. but i have had to drill out a few that i could get the heads knocked off of. i have used several methods to get the heads off of the rivets in the past too. a hammer and chisel is the easiest when yo ucan get a good position to use it. i have also used a sawzall in the harder places to get at places on the frame. this is usually where i have had to drill them out at too. and then a grinder. but you cant get a grinder into all the tight spots either.
belair53
Post by belair53 »
I cut off the heads of the rivets with a grinder but couldn't knock them out so I started drilling. AND YES ITS GIVING ME FITS!!! But it will be worth the effort to see the finished product.
For with God all things are possible. Mark 10:27
53 Chevy Belair, 68 Ford F100, 86 Mercury Grand Marquis, 93 Ford Splash, 96 Mazda 626, 06 Nissan Altima. All My Rides.
sport71
Post by sport71 »
I cut the rivits once with a large sharp chizle held with vice grips, and a 3lb. small sledge.
Calvin Gunter
Post by Calvin Gunter »
Get an air chisel.
It'll go a lot faster.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
BobbyFord
Post by BobbyFord »
I cut an X in the rivet head with a cut-off wheel, then chop the heads off with my air chisle, then switch bits to a center punch looking bit and blast them through. Because of tool clearance issues, this is not possible on all ritets but saves a bunch of time and knuckles on the others.
belair53
Post by belair53 »
I finished the hanger flip tonight and installed a new center support. Now I'm having a problem getting the rear driveshaft back in. Does the shims have to be installed before the rear driveshaft will fit after doing the hanger flip?
sport71
Post by sport71 »
Bussy day today. The shims need to be instaled when you are setting the angle. Something doesn't sound right because you should be able to install the drive shaft.
belair53
Post by belair53 »
I don't have the shims yet but what I did was unbolt the hanger and lower the rearend. Then I installed the driveshaft with the hanger unbolted. Then redone everything. Now the driveshaft is installed and I'm just waiting on the shims.
sport71
Post by sport71 »
The yoke on drive shaft needs some in and out on the transmission or you will brake something. You just might need to have it cut the drive shaft, I had to because it had no in and out motion. I think that I might just go with the lowering hangers here in the near future, because I want my suspention to have a softer ride. Right now it's solid because in the rear shackel it has no motion, because it also needs to be dropped.
