PS Pulley size/belt 390 FE
Re: PS Pulley size/belt 390 FE
you could have ditched the second alt belt and set it up that way. there is no 4th pulley used on these trucks ever. with or without any kind of a/c. but i guess you haev it working now.
Mach428
Post by Mach428 »
You may have a problem with the AC compressor lining up with the 4th sheave as it is supposed to run from the 3rd. I used the 7AA pulley and the water pump suction hose (bottom) is very close (1/4") to the first belt but it doesn't touch.
70_F100
Post by 70_F100 »
Mapco is a company that used to manufacture compressor mounts and pulleys for add-on air.
rjewkes
Post by rjewkes »
is this right? the alt is supposed to run closest to the engine? then the ps and finally the a/c?
fuelly.com
yes in that order.
sharness
Post by sharness »
Do any of the water pump pulleys for a 390 have wider spacing.My c6ae-5809-a is to narrow, the front groove won't line up with crank groove.Groove in w/p pulley needs to be about a half inch forward.
HIO Silver
Post by HIO Silver »
I ended up stacking washers behind the PS bracket to get the pulley lined up. However, I researched this issue and 70 and earlier rigs used a different bracket than 71 and later models. That may explain why mine needed spacers when the PO (previous owner) retrofitted PS to my rig.
