welding a steering column tube
Re: welding a steering column tube
i know that is what they used before mig and tig. i dont know what kind of rod i used before. i just know it broek the brass several tiems. i gave up. i also stopped wearing that brass chuvvy belt buckle after it was has fixed the second time because tthe first weld broke .
- marz68
I tigged mine with a small gassless welder years ago and never had a problem, if gas makes it better then tig with gas is a good way to go.
- Montana71-F100
I only weld with TIG but I think it would work well. I found this article about using silicon bronze rod with TIG to weld steel:
http://metalshapers.org/101/covell/cove ... onze.shtml
It might be a good way to make a strong weld and keep from burning through thin steel.
- eggman918
Torch welded mine looks good has lasted many moons
Steve
