bare metal
Re: bare metal
My suggestion would be scrub it with a metal conditioner like DX520 (has Zinc in it) rinse/wipe it down and clear coat with polyurethane.
Re: bare metal
Ill check sharkhide out, thank youHIO Silver wrote:The best way is soda blasting... it doesn't harm chrome or rubbers.
Sealer? .. the sealer you use should be the same brand as the primers and top coats.
Or are you asking whether sealer is sprayed over bare metal before the clear. In this case, it would be clear right over the bare metal.
There is a product on the market called "Sharkhide". It is applied over bare metal and lasts a loooooong time. Moreso than applying WD-40 or other oil-based product.
Check it out: http://www.sharkhide.com/
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
Re: bare metal
Ill do some more research on this, thank youtac wrote:My suggestion would be scrub it with a metal conditioner like DX520 (has Zinc in it) rinse/wipe it down and clear coat with polyurethane.
