wobble,wobble,wobble!!!
NM5K
Re: wobble,wobble,wobble!!!
Post by NM5K »
furnitureguy-123 wrote:Is there a reliable way of checking wear in the king pins b4 you tear everything apart?
This is all very good info. I do have a service manual and so far I couldn't do without.
Thanks to everyone!!!! :fr:
Jack the wheel up and grab the top and the bottom of the tires and see if
it will rock. IE: push on the bottom, pull on the top and visa versa.
If it has noticeable slop when rocked side to side, the king pin bushing is wore out.
This assumes the wheel bearing is not shot.. That could fake you out I suppose.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
