Engine Swap
- fordboy69
Re: Engine Swap
Im actually looking at a 351m engine now instead of the 302. Will the bellhousing from my 4speed match with the 351m? and the 302 mounts will work with a 351 right. Thanks.
-1969 F100 360FE
-1970 F250 (Parts Truck)
- fordboy69
Re: Engine Swap
What should i do and what would work with my 69 f100.
-351m running condition in a 1978 Cougar XR7
-360 1970 f250
Both engines will have to be pulled.This guy says the 360 also runs, should i go with the 360, would it work with my 69?!?! need help quick, thanks.
-360 1970 f250
-1969 F100 360FE
Re: Engine Swap
the 351m bellhousing is different than the 360 and the 302 bellhousings. yo uwill need the correct bellhousing fo rthe engine you use. the 351m is a smog motor and needs work to be a good runner. the 360 is a truck engine just like everyone else has. the 360 can also be built into a 390 with a new crank rods and pistons. the 351m will still be a 351m when you get done modding it. just with more pep.
- fordboy69
Re: Engine Swap
ok thanks, he says the 360 is currently connected to a 4spd std, the same tranny as I have. So if i bought the 360 it will hook up with my tranny and bellhousing right?
-1969 F100 360FE
Re: Engine Swap
you will need the bellhousing that is hooked to the 360 now. the 302 bellhousing wont fit a 360 engine the bolt pattern is different.
- fordboy69
Re: Engine Swap
I have an inline in right now. But if i get the bellhousing from the 360 and also ill need the motor mounts from the truck and ill be good?
-1969 F100 360FE
- fordboy69
Re: Engine Swap
thanks for all the help fordman. You mentioned above that you can build it into a 390. Do you just need crank rods and pistons out of a 390 engine?
-1969 F100 360FE
- fordboy69
- fordboy69
Re: Engine Swap
Bought the 70 f250 for $400 going to pick it up friday. kinda rusty but i want the engine and a few other parts
. By the way for the 360/390 conversion why would you kneed 390 heads if the 360 is the same bore as the 390? I heard all you kneed is the 390 crankshaft and 390 rods and your set for the conversion? Does that sound right? Thanks.
-1969 F100 360FE
Re: Engine Swap
truck heads are all the same for 352 360 and 390. car heads might be different though. yo udont need to change heads to make it a 390.
- fordboy69
- fordboy69
Re: Engine Swap
Picked it up, 360 purs. I have to pull it out and go over it but that wont be for a while. Thanks, for all the help everyone.
-1969 F100 360FE
