cant remove the front shock
1971ford
Post by 1971ford »
yeah ill get one. i know of a few things i can use it on allready. like the spare-mounting bolt. the big long one. its stripped and stuff and wont come out.
-Ryan
wildcard
re: cant remove the front shock
Post by wildcard »
I had to remove all my bed bolts recently and some of the shoulders were rounded off and I couldn't get anything on the domed heads. A grinder with cutting a disc got up inside the frame and cut them in no time. I tried to get one from the top and accidently let it get into the bed. So now I have a 1 inch cut to get repaired in an otherwise solid bed. :(
LOWERED 69
Post by LOWERED 69 »
If you have a propane torch you could try heating it up the best you can and let it cool. The heat will expand the metal and break any corrosion in the threads. :2cents:
Dan
'69 F350 Crew Cab
Wes
Post by Wes »
On rusted shocks that are going to the scrap pile. I put a deep socket on rod nut then the longest extension I can fit, to use as lever and work it back and forth till the rod breaks.
Wes
67 F250 High boy
69 Bronco
1971ford
Post by 1971ford »
Wes wrote:On rusted shocks that are going to the scrap pile. I put a deep socket on rod nut then the longest extension I can fit, to use as lever and work it back and forth till the rod breaks.
oooooooo i shall give that a try
-Ryan
binder56jd
Post by binder56jd »
as stated above right angle grinder
or
the liquid wrench--better known as the oxy/acetylene cutting torch :thup:
now serving #235
mk
Post by mk »
Last time I changed front shocks on a bump I used two visegrips at the top of the rod, under the spring mount. They had just enough grip to allow me to break the nuts loose. Suspension rust isn't a real big issue here though. A little bit of weasel whiz and a breaker bar are usually good enough.
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
binder56jd
hey is that weasel whiz from the same outfit what makes panther p i s s ??? :wink:
now serving #235
mk
Post by mk »
aye :D
mike
~Will Rogers
