Experimenting pays off! I installed the master cylinder then bled the brakes alone! Anybody ever done this? I pumped the pedal then I just used some firewood to prop in between the brake pedal and seat with a towel in front of the seat for protection. As the pedal rises as the procedure continues,I simply moved the seat back.
Well, it worked! So you don't always need a second person to help you bleed the brakes.
Now the warning light stayed on. The brakes seemed a little strange but they worked. So, I again experimented (not even thinking about the light) and tried locking them up a few times. At first only the left rear locked up. Then I drove a hundred feet or so, pumped the pedal once, then tried again and both rears locked. I did this a total of 4 times and the last time all 4 locked up as they should when you stomp on the brake. I happened to look down at the light because the brakes now felt normal again and "Hey, the light went out!"
I was reading all these posts about how to reset it and I think all you have to do is bleed the entire system and then drive around a bit and lock 'em up a few times. Well, it worked for me anyway. 2 cents
