Which spindle and king pin set did you have???trickf100 wrote:I bought DJM beams and had to return them. The king pin bore was .008-.010 over size from factory specs. I know a few others in this forum have had the same problem and have to find either expensive or extremely creative ways to fix the problem. I even called DJM and they told me to just crank down the king pin retaining pin to hold it in place. Wrong answer..
I'm wondering the same. Is the problem like above encountered when using the earlier kingpins? maybe they figure it's OK to be loose on the beam as long as it's tight at the spindle??69timemachine wrote: I wonder how DJM is getting away with producing a single part number now? Maybe they supply all beams with the small kingpins and include two sets of kingpin bushings? A set of thin bushings for the early trucks and thick bushings for the late trucks? I don't know, that's just my personal guess. It would make sense why the beams are higher now. Anyone who finds out, please let us all know.
