good grinder to buy?
- kilog55
i was looking at the dewalt in the case from lowes its a little more then the one you linked to but it is 10amp and you get a case.
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
- 1971ford
i got the firestorm. this thing is a BEAST.
i dont know how much bettter you can get!
reason i got this instead of the dewalt, is because this one has a trigger and a trigger lock, the dewalt has a switch on the side towards the front which i would hate! with the trigger you can turn it on and off constantly while you quickly find a new spot to grind.
i have think undercoating and dirt on the bottom of my bed, this thing tore right through all that the second it touched.
i couldnt believe it!
-Ryan
- 72stepside
re: good grinder to buy?
I wish my dewalt had the trigger.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Hedman Headers
Disc Brakes
- RedneckTexan
- averagef250
Hands down, Black and Decker makes and has made (for the past 50 years or more) the best electric grinders money can buy. I have bought, used, rehabilitated and tossed quite a few grinders since I stuck my first rod and the B&D's go ten times longer and work harder than anything else you can get.
I have a whole mess of grinders mostly BD, but there are a few Milwaukees mixed in. The ones I use everyday are a BD 4" that someone gave me 15 years ago and I stuck new brushes in. It looks like it went through Hiroshima, but it still runs like a top. And an ancient BD 9" model 590-5 that I've had so long I have no idea where I even got it from. It's so old it has a wood side handle and I've replaced the cord atleast 5 times. The only thing besides the cord I've ever had to touch on it is I replaced the switch with one from a newer BD because the old switch was a push-on push-off type deal that wasn't too safe.
Comparatively, the BD 9 inchers will hog steel with a coarse wheel as hard as you can push it through. The milwaukees bog down pretty good and I keep them set up with sanding discs and wire wheels.
Well since you already bought one i was gonna suggest this one i have one and it works great.
http://www.lowes.com/lowes/lkn?action=p ... lpage=none
I dont know how many rpms the 3m disks can handle but always check it to make sure before you use. Having a disk scatter apart on ya can be dangerous.
For grinding out small dents for filling with bondo i would get one like this they are great for this task.
http://www.harborfreight.com/cpi/ctaf/D ... mber=97187
Foggy
Foggy
