the V.I.N is F26YCH17---
the codes from the door tag are WB131 Color M
Model F262 Body 2-8 Trans A Axle 24K Max Gross 7,700 Net HP 170 RPM 4100 DSO 41
1970 Dually 4x4
re: 1970 1 ton 4x4 info
Least as far as I can figure it out..
F26- f250 4x4
Y - 360 cid , 8cyl
C - built in ontario canada
H17_ - built in dec of 69
WB131- long wheelbase
M- Wimbledon White
F262 - 4x4 7,700 GVW
2 - Lt./Med. Blue interior
8- Chassis Cab
trans A- 4-Speed new process 435
axle- 4.10 - Dana 60 3,500
max- 7,700
net hp- 170
rpm- 4100
dso- Chicago
F26- f250 4x4
Y - 360 cid , 8cyl
M- Wimbledon White
8- Chassis Cab
max- 7,700
net hp- 170
rpm- 4100
dso- Chicago
Tony
bumpless but still diggin them....
- FLATBEDFORD
That would explian why it looked shortened, and the lack of rear helpers.
Steve
My Photo Gallery
My Photo Gallery
- e350v8
Hi 1970
Wellcome -The Germay
Gruß Frank
Gruß Frank
Hallo Zusammen
Schöne- Grüße aus dem Sauerland
Ford E350 V( Diesel
Ford E350 V( Diesel
everything on it looks original untouched i know who bought it new i heard a story from more than one source saying that he bought it and put a wrecker bed on it to haul pepsi trucks when they broke down thats why the caution light and spotlights are on there as far as i know it hasn t changed other than the owners i dont know what the DSO 41 means but surely it means something dont know if all trucks have them or not will try to get more pics any perticular section of the truck just ask and i ll get it soon thanks for the help so far yall have been a big help
- 72hiboy4x4
If you all remember my (recently departed) F-250, it had a Dana 70 Dually rear axle I installed under it. Bolt in operation for the most part, just had to replace the U-bolts with the proper size and length.FLATBEDFORD wrote:DRW 4x4s didn't come from the factory until the '80s. It's a conversion fror sure, but the question is by who? There were companies that made conversions, Napco was one and I can't think of the other now.
What is the width of the frame in the rear? The DRW 1 tons are 34" wide. The SRW trucks may be be wider (they are on the newer trucks)...
Not hard to convert the front, just find the right spacers, and install them and the wheels...
Funny thing, I showed the OP's other post to my wife and it took 5 minutes to convince her it wasn't my old truck!
