69twotone,
Did you look at the picture Keith put on of where the VIN is on your frame? If not, here is the link:
http://www.fordification.com/VIN.htm
Not trying to insult your intelligence...I learned by doing, then saw the picture and found them.
drivers door replacement. vin#?
- 69twotone
re: drivers door replacement. vin#?
I cleaned and cleaned
in the area under the hood and could not find anything. When I pull the cab I will look for the one on the rail.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- two-bit
Not really bump related but it is VIN related.
The first generation F-series trucks had VIN tags on the glove box door. Held on by sheet metal screws
Also a VIN tag on the firewall, also held on by sheet metal screws.
How easy would it be to make your '50 F-5 cab, a '48 F-1 cab.
Times change.
Two-bit
Times change.
Two-bit
