how to access a bed bolt
re: how to access a bed bolt
Just drilling (or grinding) the head away will accomplish nothing. The rest of the bolt will still be held captive by the J-nut.
Just buy (or borrow) a small angle grinder and put a cut-off wheel in it...it'll make short work of the bolt. Of course, I'd try the PB Blaster route first...you might get lucky.
- 1971ford
Come in a can like brake cleaner or carb. cleaner. That stuff is the best. Can you see the bolt from the bottom. If so, I would buy a can and soak the bolt and let it sit.
theres a pic
http://www.midwayrentalsandsales.com/st ... LASTER.jpg
Kyle
theres a pic
Kyle
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
- rjewkes
a die grinder runs off an air compressor. pb blaster is liquid wrench.
if you get one of the 14-20 dollar ones be sure to get a good water trap for your compressor.
fuelly.com
fuelly.com
- 1971ford
What I do is take off the guard and kind of sit up under the truck, then hopefully you can see it and soak it. That will break it loose. That what I do. If not, then I wouldn't worry about it.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
- 1971ford
E-bay the auxiliary tank setup...and buy yourself a nice electric angle grinder.
It's one of those tools in my shop that I'd be lost without. If you need to cut something, you can put a cutoff wheel in it. If you need to sand, grind or strip paint, there are appropriate attachments to quickly get the job done.
- 1971ford
yeah i have actually wanted one for a while to help get the tough rust off of my cab roof because my electric sanders arent tough enough. now that i have another excuse, i think ill go get one this tomorrow or at least before next summer. what is a decent one to get? like a brand name or link or something. i dont know much about angle grinders.
-Ryan
