wood floor conversion in a 68 swb fleetside
- tybob81
re: wood floor conversion in a 68 swb fleetside
I started to stain the boards and I'm off tuesday so I work a little on it.
- FormerMarine1981
Re: wood floor conversion in a 68 swb fleetside
Did you finish this? How did it turn out? I have thought about this myself. None of the pictures are working any longer, do you have a photo album link? Thanks, Ben
I, too would like to see all the pictures!
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
- tybob81
- FormerMarine1981
That looks good. How difficult would you rate this mod?
That does look terrific. Nice work.
55F100
55F100
- 1967AceStroker
I really like how your truck is coming out. I have a '67 shortbed and I want to get rid of the in cab tank, but theres not as many options for a shortbed except a in bed tank, or something custom underneath. And I saw that the tank you used was a mooneyes 20 gallon tank, I didn't see a 20 gallon on thier site, just up to 5 gallon. Was it like a special order from them? And also I was wandering where you got the wood bed kit from?
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
- tybob81
The tank is custom ordered from a speed shop I found a while back. I wanted to order another one for a 49 studebaker truck I wired but the number don't exist anymore. Im not sure if I'm still going to use it or not I also have stainless tank under the bed too. We made the wood flush with the floor so we had to make 2 new center crossmembers, modify the front crossmember and make a back ledge for the rear of the boards to rest on. As far as time envoled we have posibly 30-35 hrs tied up in it. Thats drilling out all the spot welds holding the steel floor and center crossmembers, making all new braces and crossmembers, fitting the boards and strips. Not for your average do-it-yourselfer I would say.
- 1971ford
Underbed tanks are possible under short beds too, just like longbeds!1967AceStroker wrote:I really like how your truck is coming out. I have a '67 shortbed and I want to get rid of the in cab tank, but theres not as many options for a shortbed except a in bed tank, or something custom underneath. And I saw that the tank you used was a mooneyes 20 gallon tank, I didn't see a 20 gallon on thier site, just up to 5 gallon. Was it like a special order from them? And also I was wandering where you got the wood bed kit from?
Heres Keith bolting one on his SWB http://www.fordification.com/my67-p44.htm
-Ryan
- tybob81
The 73-77 rear mount hi-boy tank is super hard to find. When you call places that sell replacement tanks they don't have them.
- tybob81
I did make an end cap piece for the rear to cover up the edge and finish it off but its not in the pic. Its painted green also. I originaly had one chromed but didn't like it so it was at the chromer when I took that pic.
- FormerMarine1981
Yeah, my fabrication skills are limited. I don't have a good welder or a plasma. All I have access to is a cutting torch
