I don't know if this is for you but I intend on building
one of these homes and garage. Check out:
http://www.monolithic.com
Here is an example of what a monolithic dome shop might look like.
Dan
potential garage, I hope!
- dolinick
re: potential garage, I hope!
2003 7.3L F250
1968 F500 Utility Truck
not sure where you at on building your garage but if your worried about the "man door" taking up space for you bench, have the door open the other way. Have it open out, instead of opening to the inside.
- theskytoucher
I know here in AZ exterior doors have to open into the structure, it might be different where you are but id make sure and check first!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- Kurt Combs
Ok, I have the money to start building my garage. I will start working with a draftsman soon for county approval of plans. I am pretty set on one side being higher to accommodate the lift, but now I am thinking about a jib crane. Anyone have experience with having one in their garage?
Kurt
1972 F-250
1972 F-250
