...and if you don't have access to a slide hammer, here's a quick trick that'll work 99.9% of the time.DuckRyder wrote:Yes, but.jzjames wrote:RE: puller...
Isnt there a slide-hammer type puller that is used specifically for pulling the axles out?
You have to get the drum off and remove the 4 nuts on the bearing retainer/backing plate.
First of all, obviously you'll have to remove the drum and then the four nuts holding the axle mouting flange to the axle tube:
Then just reinstall the drum backwards, and thread at least three of the lugnuts back on a few turns:
...and simply use the drum as the slide hammer. Normally a few pops in an outwardly direction will slide a stuck axle right out:
