F350 brake question
- FLATBEDFORD
I drove the truck 71 Long Bed was talking about yesterday. IMO one would have to be firing on less than all eight to carry any significant weight in a non power brake truck on anything but flat land.
Steve
My Photo Gallery
My Photo Gallery
- ICEMAN6166
re: F350 brake question
well i can assure you i am firing on all 8.
i will be the one stopping with or without the engine running , and also steering the same either way.
no offense but i prefer the setup i have and it has proven itself to me so i will keep it as is.
- averagef250
Driving the truck and seeing first hand the brakes suck aside, Has anyone verified that the stock manual brakes are actually working right? That's the whole point here. It's not whether or not Jim Bob's brakes suck it's whether or not he's actually done anything to make sure they're working the way they should. I've driven some death trap brakeless old fords. The reason they didn't stop for beans wasn't because the brakes were manual ones, but because the braking system needed some serious maintenance. Go ahead, toss a power booster behind a manual master on a truck with bad brakes and it'll stop better. Fix the real problem and they'll stop even better.
- zakt
My 67' F350 came with Vacuum Booster brakes and is 8000GVW.. Will be installing hydraboost
even with my 95' 1 ton (10000GVW) I cant stop on a dime so no tailgating.
1972 Ford F350 crewcab
- 71 LONG BED
I realized this weekend that the power brake booster wasn't a stock option. How did I know? There are 3/4 inch nuts being used to shim the booster braket away from the firewall.
John Member #1549
