Here's a few pictures borrowed from Barry of an alternate course of action for adding a second shock. Since the spring tower is the same piece on both sides, the hole for the upper shock mount is already there, and this enterprising person simply welded some tabs onto the I-beam for the lower mounts:
I've also heard of one instance where someone took the factory swaybar mount bracket and used that as the lower shock mount. The bracket I'm referring to is the one which mounts under the front spring. I believe he simply mounted a shock stud where the swaybar's link assembly would normally attach. The bracket is the piece numbered '5C499' in the attached diagram (lower left corner).
